Nameite
Ok here's the prob
Got a cheap 2nd Sapphire X1600 pro AGP, slotted it into a working Asus P5PE-VM in a Antec MSK3300 (300watt psu)
Push power button...all lights and fan comes on...dvdrom spins...hdd makes a bit of sound then stops....and stays that way...for a long time
Tried it a few times then gave up and went for lunch....came back pushed button....then....
it works!
tested it all night, played some games, encoded some files...
Next day morning....works fine still, everything normal....ok call my friend to come pick it up....
4pm....he comes....problem is back....all lights and fans comes on....no splash screen, no nothing....nothing nothing nothing...blank screen, no video input....tried with a 9250...works fine....tried with onboard....works fine....tried 6600GT...works fine....
Is this an incomparability issue or is this card just whack?
I dont wanna go back to the guy I brought it from and krap all over him to find out its my prob....like I did with an ADSL router a while back
Well gonna do bios update later tomorro if I cant find no solution...any advice anyone?
it works!
