"ghosting" on LCD
silkman
I've recently noticed white shadows on the borders of some windows on mylcd-how can I correct this? I tried resetting to factory settings but it persists.
What do you mean? When you are moving the windows around or a stationary white window on a dark background gives a white 'shadow'?
Yes, I'm using a cable
Stationary dark window gives a white shadow or vice versa
VGA cables sometimes do this. Rather use a DVI or HDMI cable if you can. You won't have any ghosting problems.
For the moment though, try playing around with the "sharpness" and "fitness" settings on the screen.
ok ..played around with the cable and the ghosting disappeared- thanx dude
