gobii Phones not detecting CellC 3G network?
HideInLight
Got two of them for my parents, they come with two CellC 200Megx12 deals sim cards.
However when I search for the Networks available with those phones I only find CellC 2G network.
Anyone have experience with those phones or tell me what I should be looking for to see if it has support for CellC 3G networks?
http://www.keenoncapetown.com/gobii-smartphones/
Looks like it doesn't do UMTS900, so you're stuck on EDGE unless you are close to one of the few Cell-C base stations that do UMTS2100.
gobii 4″ Smartphone IIP
  • Processor: MT6572 Dual-Core @ 1.3GHz with dedicated graphics processor
  • O/S: Android version 4.2.2 (Jelly Bean)
  • Display: 4.0″ WVGA IPS (Resolution: 480 x 800) with Dragontrail glass screen
  • Storage: 4GB (Extendable up to 36GB with an external micro SD card of up to 32GB)
  • Memory: 1GB RAM
  • Camera: 5.0 Mega-Pixel rear camera (software enhanced to 8 Mega-Pixel); 0.3 Mega-Pixel front camera (software enhanced to 2 Mega-Pixel)
  • Dual SIM (accepts standard size SIM card from any network provider)
  • Connectivity: 2G/3G: GSM900/1800 and WCDMA2100; Wi-Fi: 802.11 B/G/N; Bluetooth: Ver. 4.0
  • Battery: 1150mAh Lithium Polymer Rechargeable
  • FM Range: 76 108MHZ
  • Dimensions: 123mm x 63mm x 10mm
  • Weight: 126g
  • Ports/Slots: Micro USB, AUX 3.5mm, Microphone, MicroSD (max. 32GB), SIM (Dual)
gobii 4.5″ Smartphone IVP
  • Processor: MT6582 Quad Core Cortex A9 @ 1.2 with dedicated graphics processor
  • Display: 4.5 FWVGA IPS (Resolution: 480 x 854) with Dragontrail glass screen
  • Storage: 8GB (Extendable up to 40GB with an external micro SD card of up to 32GB)
  • Memory: 1GB RAM
  • Battery: 1700mAh Lithium Polymer; charges via USB port or wall charger
  • FM Range: 87.5 108MHZ
  • Dimensions: 132mm × 66mm × 9.8 mm
  • Weight: 156g
Never assume...
Why give CellC data, if the phone doesn't support CellC 3G?
At least whatsapp messages go through, but I will need to create a 3G hotspot to actually update and download the apps.
Because lets face it, edge sucks.
Well, they only give you 200MB, so it's perfect for EDGE. :p
I beg to differ. It is about your needs, not a speed. :)
I use two R49 RBM starter packs and four Telkom Mobile. When one is finished, SIM swap, and so...
