cerebus
I think the ram issue is really overrated personally. I've never experienced the slightest problem with ddr2800. Even DDr2667 is ok tbh. But 800 is so cheap nowadays that it's best value for money.
is there a significant difference between 7200rpm hdd's and 10000rpm hdd's?
shouls i get 4 x 512mb ram to utilize all 4 slots,4 x 1gig or 2 x gigs?i'm still novice on the dual dimm config and i've heard from some bright sparks that you can only enable dual channel if all 4 slots are used.which i think is bullshiet....i've seen guys only use 2 slots but to according colors of the slots...............![]()
CPU - http://www.computersonly.co.za/productdetail.aspx?sku=BX80570E8400&categoryId=36087
Mem - http://www.computersonly.co.za/productdetail.aspx?sku=MEA4096MB800G&categoryId=36116
GPU - http://www.computersonly.co.za/productdetail.aspx?sku=SAP211320440R&categoryId=36093
Mobo - http://www.computersonly.co.za/productdetail.aspx?sku=ASUSMP5Q&categoryId=40359
HDD - http://www.computersonly.co.za/productdetail.aspx?sku=ST3500320AS&categoryId=36101
PC Case - http://www.computersonly.co.za/productdetail.aspx?sku=CMRC690&categoryId=47039
PSU - http://www.computersonly.co.za/productdetail.aspx?sku=GEP585AC2&categoryId=44396
22" LCD - http://www.computersonly.co.za/productdetail.aspx?sku=2253GW&categoryId=36129
DVD - http://www.computersonly.co.za/productdetail.aspx?sku=SHS223&categoryId=36079
Keyboard - http://www.computersonly.co.za/productdetail.aspx?sku=flexcskbwb01&categoryId=36108
Mouse - http://www.computersonly.co.za/productdetail.aspx?sku=STARMOUSEGS502&categoryId=36110
And that is if you buy everything at the same place, if you shop arround, you could get better prices or hardware...
R15k Blown.![]()
Back to the graphic cards.should i go hd4870 or hd 4780x2?
Naughty SB, you included the 500GB Seagate drive.
