graphics card help
flashfire208
JHB
Hi guys
Plugged in a nvidia 8600 today and while the system recognises it while its booting in Post , once it goes into windows the system no longer recognises there is a card in the slot, yet the monitor is plugged into the card and displaying windows :confused:? And its NOT a driver issue , i eliminated that possibility.
I plugged my old 6200 in and that works just fine, So any idea's ?
Hi guys
faulty card perhaps???
Hi guys
Does it not have something to do with the slot speed? Read the manual of your m/b and gfx card and double check that there is no BIOS setting or m/b setting that needs to be changed/tweaked.
Thanks subculture , i will try fiddle with those tm . It was working a few days ago in a friends PC
Hi guys
If i understand correctly, what you are trying to say is that you cannot detect the card in device manager. Sounds to me like it is more likely to be a software issue than the card itself, especially if you have it plugged in and are able to use it. May be something in windows that is corrupt and causing it to simply not show up in device manager or it may be some kind of malware. I have heard of malware making devices dissapear from the device manager in windows; although i have yet to see this myself.
When was the last time you did a complete format and reinstall of windows?
Haha ummm wellll ummmm errr *cough* 2.5 years ago *coughs*
And yes , i cannot find it in the hardware manager and when i try drivers it says drivers not compatible for current device - and i tried ALOT of drivers . So your probably right , its a windows issue.
lol, kk... might want to get the window lean out and give them windows a quick once over ;)
