aka.Goliath
I have an Asus AMD HD 6870, which is factory overclocked, and with the drivers came a program called asus smartdoctor using this I have noticed that when playing games (crysis 2 ect.) the running temperature can peak at 80 degrees and average at 70-75 degrees. My CPU is normally at 60-65 degrees when in use (using coretemp). My case is an Antec 300 which is a bit full but air flow seems good. What I want to know is if these temps are a normal running temps or should I be taking some steps to try cool it down? Perhaps a fan at the front? Also how much of a difference does a cooler gpu make to performance?
