Why not just ask the guys installing the grey boxes?
they did the installation when I was at work in our street and the time I get home from work than they already gone
is it possible to share a grey box with a neighbour? Will see if I can take a drive home and ask them if I see themI don't think it will be a problem as long as they add you to the coverage map. The install might take a bit longer maybe but I don't think it's reason for concern yet.
No, you should have one of your own. Get hold of vumatel on social media (twatter) and ask.is it possible to share a grey box with a neighbour? Will see if I can take a drive home and ask them if I see them
What do they do if you don't have a wall in front?
Maybe @pinball wizard can shed some light on that for usWhat do they do if you don't have a wall in front?
thanks going to phone them and have a chat to themNo, you should have one of your own. Get hold of vumatel on social media (twatter) and ask.
Hi
They are busy installing fibre in our road (vumatel) and I am the only house in my street without a grey box outside my houseShould I phone someone to ask why? or anyone else experience this before?
That's probably how they get fibre to homes without a wallYou actually don't even need the grey box. My mom had the same problem when she had her fibre installed. No grey box, but all her neighbours had one. Turns out there was a small square Vumatel manhole cover right in front of her wall embedded in the pavement. When they came to install they just dug up a bit of the pavement, installed a plastic sleeve into the ground running to the manhole underground and connected it up directly inside the manhole. I assume whatever happens in that grey box can also be accomplished in the manholes if it is right next to your wall in the pavement.
I only have a vumatel manhole outside my houseDo you have conduit running to your property?
aah okay I also got that manhole thing in the groundYou actually don't even need the grey box. My mom had the same problem when she had her fibre installed. No grey box, but all her neighbours had one. Turns out there was a small square Vumatel manhole cover right in front of her wall embedded in the pavement. When they came to install they just dug up a bit of the pavement, installed a plastic sleeve into the ground running to the manhole underground and connected it up directly inside the manhole. I assume whatever happens in that grey box can also be accomplished in the manholes if it is right next to your wall in the pavement.
As long as that's there they can tap you a line,either to your own grey box or directaah okay I also got that manhole thing in the ground
