GTA 5 for PC delayed, system requirements revealed
I have too many games to deal with anyway so probably wouldn't have bought this for quite a while. As long as it's a great port the delays are insignificant. Mods will keep GTA V alive for many years, so a few more months to release it is nothing.
No problem with this as long as its not as bad of a port as gta 4
This is the correct response.
They look pretty indistingushibale from the PS4/Xbox One screenshots:
http://www.rockstargames.com/newswi...ft-auto-v-release-dates-and-exclusive-content
The difference is you can throw a lot of money at a rig to play it in 4K where as with the consoles you're stuck at 1080p which is fine as most TVs are that.
Well to be fair if you're playing on a potato it's more likely to be 720p @ 30fps
