[H] Web development help
chrisc7890
Hi
I need alittle help or guidance, I want to do a simple page where any user can input a telephone number (so it has to only allow numbers and has to only be 10 digits) then it has to save it to a txt file or database and other use should be able to type a number in a search box and it will say if it's on the site or not
I am using softaculous and need to know what program I should use to do this in
HTML Forms to input the number and PHP script to read/write to file/database should work.
This ^
Code:
<form method="POST" action="myPhpPageThatDoesTheSaving.php">
    <input type="number" maxlength="10" name="thedeets" />
</form>
