Virtualizor BGP Hijacking
Jade @ Absolute Hosting
Absolute Hosting Representative
Company Rep
Company Rep
Centurion
Dear Customer,
We are writing to inform you about a security incident involving a BGP hijacking that affected a block of IP addresses used by Softaculous services, including infrastructure serving Virtualizor.
Incident Summary
Between 28 August 2026 ~20:57 UTC and 30 August 2026 ~06:10 UTC, an unauthorized network announcement diverted traffic destined for 162.55.80.0/24 to an attacker-controlled server. The affected infrastructure included our software update endpoint and client-area services.
What Happened
Traffic was redirected through a BGP hijack
An unrelated network began announcing our IP range using a more-specific BGP route. This caused traffic from some networks to be redirected to an attacker-controlled server. The attacker also obtained a technically valid TLS certificate for our domains, so affected connections did not display a certificate warning.
Virtualizor
Malicious Update Package
A malicious Virtualizor update package was delivered to a small number of installations whose update requests completed while traffic was diverted.
Routing Status
Fully Restored
The unauthorized route was withdrawn and normal routing was restored globally on 30 August at approximately 06:10 UTC.
Action Required
If you run Virtualizor, please check your server 1. Check for the indicator of compromise: look for /etc/systemd/system/java-jre-update.service. If it is present, do not simply delete it; contact us.
2. Rotate Virtualizor API credentials: reset all API keys, restrict API access to trusted IP addresses, and remove any key you do not recognize.
3. Audit access: review SSH keys, user accounts, scheduled tasks, cron jobs, and unexpected outbound connections. Restrict SSH access to trusted IP addresses.
4. Run our security scan: Virtualizor Security Scan https://files.virtualizor[.]com/security/virtualizor_security_scan.sh
5. If you find signs of compromise, contact support before remediation so we can help preserve evidence.
Other Softaculous Products
No malicious package identified
We have not identified a malicious package for Webuzo, Softaculous, Backuply, SitePad, or our other products. As a precaution, if one of these servers performed an update check during the incident window, please verify the server for anything suspicious and contact us if you find anything unusual.
Client Area & API Keys
If you logged into the Softaculous client area or entered payment details during the incident window, your session may have been diverted. We recommend resetting your client-area password. As a precaution, regenerate the client area NOC API keys and update them on your servers.
Full Incident Report
Detailed timeline, measurements and findings
We have reconstructed the incident using public routing data, including the timeline, impact measurements, indicators of compromise, and the actions we recommend. Please read the full report for complete details.
Read the Full Security Report https://www.virtualizor.com/blog/security-incident-bgp-hijacking/
The fact that ISPs still enable BGP hijacking is just....
This is of far greater concern. You would need elevated access in a domain to produce a valid CSR. Sounds more like someone is in the habit of leaving full PFX exposed for all to take and abuse as they wish.
There's no elevation required to generate a CSR. Anyone can generate a CSR claiming to represent any domain name.
Alot of modern CAs use ACME validation - all an attacker needs to do is hijack the BGP route to have the CA route the validation request to the attacker's IP. The attacker then satisfies the challenge and is issued a cert. It starts with the BGP hijacking. No need to steal any certs. They just generate their CSR and redirect the traffic to their IP to answer the challenge from the CA to generate their certificate.
You.. .whut?
Sure. Anyone can generate it. But if you don't have SOA you're doing nothing.
A. Lot. A. Lot.
Allot == apportion
A lot == great deal of.
Not hard. Like understanding certificate signing
Da fark are you prattling on about... BGP is not a route. It's a protocol....
Grief, I'm too old for this shiat.
"BGP route" is ordinary shorthand for a route advertised via BGP
Not. Anywhere. The "P" explains exactly what it is. Protocol.
CSR is self-signed
Not. Anywhere. The "R" stands for request. It signs jack shiat.
how the CA validates control
None of this is accurate. None of it.
the CA's validation request lands on the attacker's server
None of this is true. None of it.
DNS, and the SOA, never comes into it
DNS wasn't mentioned. Anywhere. It requires a great deal more then pretense. Claiming it doesn't matter speaks to ignorance of how DNS works.
Start-of-Authority underpins everything so claiming it "never comes into it" is just... illuminating.
This is a known technique
Sure. Your understanding of the attack vector is... delusional at best.
Please do continue to educate me on how certificates work. I'm sure *you* can teach me things.
