Hamachi problem on Mweb.
Sebastian.s1994
Centurion
Hi there. Can someone please help with this. Yesterday I installed Hamachi onto my pc so that some of my friends and I can play Minecraft together on a server I'm hosting. Everything went though perfect and everybody could join the server, till one of my friend tried connecting and it timed out. So I restarted the Hamachi and now it isn't working. It keeps saying "probing" en then give a message "Failed to connect." I asked one of my friends to try and see if theirs work. He says its works but as he is on a Telkom account and I'm on a Mweb account, it might be something with mweb.....
Does anyone know more about this? Thanks
I doubt that it is Mweb. It is most likely a Telkom to Mweb issue, because Telkom does not want to peer at CINX/JINX/DINX.
Mweb has a protection feature on their ADSL accounts that you can disable on their website when you log in with your ADSL credentials.
I'm not sure if that will block the Hamachi connections, because as far as I know Hamachi does not need to accept incoming connections.
What it could be, is the order in which you arrange the network interfaces in Windows, but that order shouldn't prevent Hamachi from being unable to connect. It would only prevent you from discovering "LAN games".
Oky so we tried using hamachi again it worked and didn't have any problems so far. Maybe just a temp things. Thanks for the reply:)
