The Drive was never droppped, not to my knowledge, it was transported yes.Are you referring to a repeating 'beeping' sound that repeats about once a second, and the drive does not spin up?
If the drive is 2.5" then the problem is most likely stiction, where the heads stick to the platter as they did not return to the ramp before the drive spun down.
Stiction on 3.5" is very, very rare. Some drives are very prone to seized spindles, Seagate 7200.11 the most common. Motor spindles will often seize if the drive is dropped. Was it dropped?
Give a bit more info leading up to the failure, and the details of your drive.
What model of drive is it?
That side of the country I would recommend Tecleo - www.datarecovery.co.za
Could be stiction as EARS park heads on a ramp, and this series is not known to have easily jammed motor spindles. Stiction should be cheaper to recover from than a seized spindle.
Tecleo could probably do it right away, but be prepared for a 'priority' fee of quite a lot of Rands.
What does Stiction mean?
How much is a priority fee?
They quoted me R4500 for a economy (5-7working days) and R6000 for speedy (3-5 working days) that was on stuck spindle, would stiction be cheaper and what is the chance of getting all the data back?
Regards
Peder
South_Bit:
Do you guys get a lot of WD20EARS drives? I bought 3 of them, 1 acted up, another reported a couple of bad sectors.
However I've bought 18x Seagate ST2000DL003 thus far and had 2 failures total in 2 years (and these drives run 24/7 in servers and never go into low power modes, eg. full power, full acoustic, etc.)
I guess it is possible that it is bad luck (I owned 5xWD20EARS about 3 years back that I sold and they had 0 problems). But I'm starting to wonder about these WD drives.
EDIT: Sorry if this is a hi-jack Peder, just curious. If it bothers you I can remove my post...
I hope it's really important data that you want recovered for the price quotedwhy no backups?
Try James at CSSI in Midrand
seems in the end it was a hard drive crash which can not be recovered... thanks for your help guys!
I can only imagine the platter/s were damaged. What was the prognosis?
Why?
