Harmony 895 Advanced Universal Remote
rpm
Admin
Staff member
Johannesburg
Posted by: caps
Description: Harmony 890 - ftr - Total Command One trigger finger is all you need. * No Line of Sight Needed: You can put your components in the cabinet or even the next room. * 30 m (100-foot) Range: Go ahead and build the big media room. * One-Touch Control: Choose the activity you want to do, not the component you want to turn on. * Up to 15 Components: Control video, audio, gaming—even lights and appliances. * Learning Port: Add favorite functions from an old remote just by pointing it at your Harmony. Harmony 890 - ftr - Comfort & Convenience Comfort and Convenience Never get numb-thumb again. * Charging Station: Put your remote in its own home and forget about changing batteries. * Comfort-Grip Shape: Hold on comfortably and reach all the buttons with ease. * Fully Backlit Controls and LCD Display: Navigate even in movie-theater darkness. * Help Button: Confused? Let the Help Button figure it out for you. (No one else has one.) Harmony 890 - ftr - Simple Setup Simple Setup It doesn’t get easier than this. * Online Wizard: Plug into a USB port and walk right through initial setup or adding equipment. * Incredible Compatibility: From laser disc to Blu-Ray® disc, find your components in our 175,000-device database. * Free Support: Expect total customer satisfaction, whether you have a problem or just a question. Demo Unit Price: R1200 (retail price is R2300) Tel 083 729 8877
Price: R1200.00
