F
Fudzy
Guest
Without the use of a case that is? Tried Googling but can't find anything more recent than July.
If you mean they fiddled with the code that determines how many bars are displayed, yet it's been sorted. Personally I call BS but hey the Apple has spoken.
all phones do it, the iPhone 4 doing it was just the first people took notice, and it got blown out of proportion
(probably because there was a strange software bug, that caused people to take notice)
Nokia's, Blackberry's and semens do it too.
*This post is most likely sarcasm, satire or a joke.
It's probably just garbage, though.
Due to the antenna being on the outside, signal dBm and SNR have been improved to a level above that of the 3G and 3GS, - so if you happen to do a death grip on the iPhone, then it will reduce your signal to the same level as what you would have with an iPhone 3G or 3GS. In other words, you are not likely to drop anymore calls than what you would on an iPhone 3GS - even if you are giving it a death grip. If you hold it normally, you will have better RX sensitivity, and in fact are more likely to drop a call on the older iPhone first.
Crunch the iPhone 4 like you are throttling a python = same signal level (dBm) and SNR as an iPhone 3G (held lightly/normally)
Hold the iPhone 4 lightly (in a normal fashion) = better signals than a iPhone 3G (held lightly/normally)
So what caused the consumerist to not recommend it?
I have had my iPhone 4 for 9 weeks now and have never had a reception problem. Seems all the complaints originate from the US, but there are no complaints from Europe or anywhere else really...
Well got mine last week...I could do just about anything but could not make out going calls,called MTN on several occasion to try and fix the issue still nothing happened. Till today for some reason I now can make my calls only if I hold it a certain way.
Could I be the only one who experiencing lssues with the anthena problem?
