Hellllpppp.... PC monitor
OMG!!!
Dudes
ok my pc just did the following when booted
windows comes up.... then all of a sudden monitor turns off ??
did tell me something about LSA shell bla bla
any ideas
No idea what LSA is...press f8 repeatedly while the pc starts up before the windows logo shows,windows boot menu will appear,select VGA mode
Wow... you're good! :eek:
Posing without using a monitor... I've never been able to do that.
no dude win xp ok going to try VGA mode all this because i did a system clean up
no the dam screen switches off when machine logs on to windows
AAAGGGHHHH
cant even get in with safe mode
GJ! Try logging into Directory services restory mode in the same boot menu?
enable ~VGA mode
did the same thing :( gonna have to re-install win hey ? dont tell me that plz
safe mode scrren comes up i see my wallpaper then it switches off again ??
all modes same thing happens ??? so confused never had this before
If I have given this advice once I have given it a thousand times, format the pc as well as every pc in the vicinity!
lol and if i do that and it keeps on going on can i take my 9mm and blow it away
why do pcs have to give so many problems ??
GGRRRRRR blady thing now i have to backup everything and redo the dam thing again
Fire up the XP install CD and do a repair.
You've clearly gone and buggered something with that clean up you mentioned.
Yeah, do a repair; it will fix almost all problems. What did you do you do (or use), to clean/fix your PC? (This is why I dislike regcleaners etc.)
