Grieta Thanburg
- Oct 31, 2022
Good morning.
Can one of the networking gurus give me some advice please. Earlier this year, I bought a second-hand Mikrotik switch off of here. The time has finally come to lay proper cabling around the house.
Since I don't have the tech to cut, mix and match fibre cables, I thought that this would work well between rooms, via the roof.
scoop.co.za
scoop.co.za
Would these products works together? Basically, Existing Mikrotik RB5009 -> module (linked above) -> cable (linked above) -> SFP Mikrotik switch
Cudy Multi Mode 10G LC SFP+ 850nm 300m | SM10GMA-03
Cudy's CD-SFP-MM10 is a duplex module designed for Multi-Mode fibre deployments up to 300m at 10Gbps. Ideal for short-distance fibre links or to provide uplink between switches, routers and media converters.
Scoop Fibre Outdoor Uplink Cable 30M LC-LC UPC 2Core
Scoop's FDC-30MU 2-core, pre-terminated, LC-LC, UPC, Single-Mode uplink drop cable is designed for SFP connections without the need for splicing.
