Help! Annoying ads on android. Anytime
candygirl
Western Cape
I am getting ads on my android phone anytime randomly. Have tried a few apps but no success.
Apps tried:
AdBlock Plus
Malwarebytes anti malware
Addons detector
Any advice?
Apps tried:
AdBlock Plus
Addons detector
Any advice?
definitely.... what phone do you have?
The next notification you get, press and hold the notification and then click the (i) then you can see what app it is.... your problem should be solved if you block notifications for that app.
