Help - Cisco 2801 router
oldBastard
Strand
Ok need some help, :erm:
What needs to happen is:
Site A <-> Middle (me) <-> Site B
I have added the routes in the routing table. I can ping to Site A and to Site B from me, but, Site A cannot see Site B and vice versa.
Do I need to "link" the two IP address' with in me to let Site A & B see each other? If so how?
Create a static route from Site B -> You -> Site A and vice versa
This is the routing table:
C xxx.xxx.xxx.xxx/24 is directly connected, FastEthernet0/0
3.0.0.0/24 is subnetted, 1 subnets
C 3.15.0.0 is directly connected, Serial0/3/0
5.0.0.0/24 is subnetted, 1 subnets
C 5.15.0.0 is directly connected, Serial0/3/2
6.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 6.15.0.0/30 is directly connected, Serial0/3/1
C 6.15.0.2/32 is directly connected, Serial0/3/1
10.0.0.0/24 is subnetted, 2 subnets
S 10.11.56.0 [1/0] via 3.15.0.2
S 10.1.201.0 [1/0] via 3.15.0.3 (Site A)
S 192.168.0.0/24 [1/0] via 5.15.0.2 (Site B)
S* 0.0.0.0/0 [1/0] via xxx.xxx.xxx.xxx
Site A = 10.x.1.x
You = 10.x.2.x
Site B = 10.x.3.x
On the router, you need a static route that says anything destined for site B 10.x.3.x is to go via the Site B interface IP, vice versa for the Site B
