OverKill69
- May 12, 2008
They came and conquered.
Connected a laptop to the car - everything appeared ok.
They then rocked mine gently back and forth a couple of times - suddenly a "beep" came out of mine - guy jumped into mine started it & got it into neutral.
Took it for a spin around the area manually shifting thru gears.
Was told it should be good, but to bring it in for a new relay and some connecter on monday.
Can tell you now exactly what happened...
When you put the car in park, foot on brake, turn off car, release brake... what happens? car rolls back a little bit...
Gear selector shifts slightly, jammed the safety lock at a funny angle that couldn't release.
Best practice is to stop car, foot on brake, put in park, HANDBRAKE, foot off brake, turn off.
You also avoid unnecessary damage to the gearbox with this technique... since the oil doesn't circulate once the ignition is off.
My mom had a '92 300SE and she ALWAYS let the car rock back on the parking brake once she turned off. After a few years, gear shifts became increasingly "jolty" because the selector sprocket was so worn by doing it. (We're talking 8 or 9 years)
