help ! i broke it !
jvk
jhb
oh cr@p!
i think i broke it !
so last night after ages i finally get everything activated mweb, adsl etc so as a first time user i ofcourse dowloaded Utorrent and the likse signed on to bitfarm and proceeded to download a torrent 350mb (some collection of songs) anyways Utorrent automatically adjusts the setting etc first question DOES THIS INCLUDE PORT FORWARDING?
next question : the torrent download speed was very very slow like 0.1kb WHY ?
last question : i left it on over night and this morning when i check on it there no picture ! checked the hdmi cable and its fine even changed back to the rgb cable and its still doesn't work ! what the hell did i do ???
took out the graphics card and plugged the rgb cable straight to the mobo but still nothing !
did i blow something ? the pc seems to start up fine just no picture
HELP HELP HELP!! i used the interwebs for one day and i already broke something
1 UTorrent does not forward your ports automatically. You'll need to set it manually first. That might explain your speeds - otherwise try a different torrent with better trackers.
2 Boy that's a mystery - you say it doesn't show even if you use the onboard video with a standard vga cable?
You didn't download something from Sony did you? Oh god, please dont say you did! If Sony pick it up they send a 4v downstream current to your VGA port which disables the Vsync and causes the problem you describe. Contact sony and once you pay the fine, they will send the necessary -4V signal to re-enable the port....
If not then try reseat your RAM and processor. Does the CPU/PSU fan spin when switching on the machine?
WTH??? :confused:
you trying to scare me aren't you ?
Yeah... :)
But seriously, try reseating your RAM and cpu....
i did put in additional ram yesterday... it picked up fine and seem to be working great...i'll check that as well
thanks
dont get any beeps off the motherboard when it starts up ?
nice one:p
Funny :D
