Mr Anderson
- Oct 29, 2005
Hi guys,
Sorry for posting another topic about this modem but I've used the search facility and the posts that have been made about it doesn't really help me. So I'm hoping you guys can
I recently bought a Netgear DG632 Modem and I've updated it to Firmware 3.4.0. I've also connected a normal 5 port switch to the DG632 and from the switch I have 2 pc's connected to it. All of my PC's are running windows XP and have IP's setup for DHCP. I need to know the following:
If I want to use this Router to share my ADSL connection do I need to have it running in MODEM or ROUTER mode?
Does it need to run in PPPoE or PPPoA?
Multiplexing Method: VC based or LLC based?
I've read some weird things about this modem on this forum. Some people say you have to use USB to connect to it and then unplug it and THEN only does the ethernet connection work. Other people had to use it as "modem" mode but then got it to work in "router" mode but they never said how they did it. I don't really care about P2P software....basically all that I'm going to use this modem for is to play some online games while my dad surfs the net...i.e normal browsing...that's it.
Thanks guys!
Thanks guys!
