Help!Line is c**k slow!!??!!
Schwartz
Hi,
I have a 4MB telkom line
Today when I got home I noticed it was very slow... so I did some speed tests and the highest I got was 41.9kb/s!:confused:
WHY?HOW?
How can I fix/resolve this?
PS:I am very close to the exchange and normally get about 3.6-3.8 mb/s
Sounds like a line fault. Check/report it on 0800-375375.
Unless it's just sh*tty IS bandwidth you're using. SAIX or IS?
i felt my modem and it was way too hot(almost burnt hand)... turned off and left it for 20mins and now its fine again!
Thanks though
um, I assume you mean... k@k slow... c**k is..um... something else.
my afrilish is a bit off lately!!
A bit ht is like saying the night is a bit dark!!
It was 42 at my house today!
Much the same it seems.
um, I don't live in Britain. Neither does the OP. :rolleyes: There is a much more common English word which can also fit the template c**k. Can you provide us with a definition for that one?
Well we do speak English, y'know. Some of us anyway. :rolleyes:
Here you are:
cock
noun dated a small pile of hay or other material, with vertical sides and a rounded top.
verb archaic pile (hay or other material) into a cock.
ORIGIN
Middle English: perhaps of Scandinavian origin.
:p:p
