Schitzo
Me AGAIN! Hiya!
I've been saving up to build my own PC. I think I have enough to build a pretty good rig. I know some of the basics on how to build a PC & what goes where.
I would like to know FIRSTLY what am I leaving out or missing from the below setup, please:
Cooler Master RC-1100 COSMOS S Tower Chassis
Sound Blaster X-Fi Xtreme Audio PCI Express Sound Card
Asus GeForce GTX275 16xPCIE 448-bit 896MB DDR3 w/HDTV + 2DVI
Seagate 1TB Barracuda 7200.12 SATA300 32MB 7200RPM Hard Drive
Seagate 750GB Barracuda SATA300 32MB 7200RPM Hard Drive
Sony DRU-V200S 48xCD-R / 32xCD-RW / 48xCD / 16xDVD / 20xDVD+\-R / 8xDVD+R DL / 12xDVD-R DL / 8xDVD+RW / 6xDVD-RW / 12xDVD-RAM SATA Combo Drive
Corsair TX750W Power Supply - 750W
Asus P6T Deluxe V2 IX58 Motherboard w/A8 + 2LK + FWa + SATA2 RAID
Intel Core i7 920 2.66GHz LGA1366 Processor
OCZ DDR3-1333 6GB (3x2GB) Platinum Low-Voltage Memory Module Kit
I'd like to know if I am missing anything from the above setup?
Will I need to buy anything else (I already have a monitor, keyboard, mouse, speakers)?
Do I need to install any additional fans?
Should I wait for an Nvidea DX11 card or go with a ATI one?
Is my PSU adequate to power all of the above stuff?
I've noticed that the Hardrives I've chosen are SATA 3.5" ones, would that make a difference ie. Have I chosen the right ones would they be compatible with my Board?
Lastly I've noticed that RAM has different Ranges & Frequencys or whatever you want to call them ie. DDR3 - 1333 or DDR3 - 1375 or DDR3 - 1600 etc. How on earth do I know which set to buy for my PC? :wtf:
Thanks!
Thanks!
