giveITback
Hi All,
Internet suddenly went down about 3 days ago. I initially just left it for a while suspecting it was some sort of temp telkom issue. But then after a day and a half I started troubleshooting. Red led for internet on the Zyxel modem. The adsl light was steady green. I immediately suspected the ISP so I changed the details to a different account with the same result. Telkom says my line is syncing fine and have done a port reset. Webafrica claim that everything is good on their side. To completely absolve the ISP, I tried the Telkom guest account with the same result.
Webafrica says that they can't see any authentication requests coming through from the modem. So, I had to assume it must be the modem. Went out and bought a new billion modem yesterday with the same result. Although in this case the led for internet doesn't light up at all. I'm assuming that's a difference in the actual modems though. (The billion probably doesn't have a rgb Led).
Anyways, after all this testing, it must be the line at fault? Two different modems with a total of three different accounts can't be giving the same issue? It's not that it tries to authenticate and gets an authentication error. It seems that it the authentication requests don't ever leave the modem...
I logged a fault with Telkom even though they seem insistent that it's not their fault. Any of you ever had a similar experience? Thanks guys
Btw, I updated firmware on both adsl modems just in case. Sadly no help
