Help me sooth my head shave!?
Looking at your avatar I can see the after pic, where's the before pic ponder?
Lol. Ok done and dusted. Took the clippers without any combs and cut off whatever hair I had (not much) and then lathered my pip in shampoo/conditioner and shaved the the rest off. Feels great, nicked myself once close to the forehead and it's bleeding like a biatch.
Mission accomplished ;)
Everyone does, he said, running his hand through his lovely locks...*
*still support cancer initiatives, even with hair...:D
Only hair I have left are pubes :D I might just entice Ockie back, that sick bastard.
If you are using a normal beard trimmer to shave you don't need anything special after the fact.
Some regular moisturiser or aqueous cream if your scalp is a bit dry.
If you use a razor then some Nivea aftershave balm works well. M
Obviously of you want to razor it, use a normal shaver first.
