I've just installed SetCPU on my Xperia Active, which runs at 1GHz stock. I'm using it to underclock to between 245MHz and 1GHz (with the 'conservative' option) to save battery power. (And to between 112MHz and 245Mhz when the screen's off.)
What I'd like to know is, does the phone (with standard Sony Ericsson ROM/kernel etc) do something like this normally anyway, or does it just run at 1GHz the whole time?
By default the phones use the "OnDemand" option, basically with the screen off it does clock it down, but when a background task begins to run like say a whatsapp/gtalk/email message comes through it spikes rite back up to 100%, so setting the screen off to a lower value you save battery power by clocking back up to a lower frequency....
I use Watchdog for just that as some badly coded applications can do that and stay there even when the phone is idle. Watchdog will alert me in cases like this esp when they stay high for longer than just picking up mail so I can decide what steps to follow for example if the app does it all the time I can simply decide to uninstall it or if its once off simply kill it.
