kimbo
Hi, from a dusty and hot freestate
Guys i really need help, i am trying to fix my wheelchair, it is a few years old but still going strong, untill two nights ago, it just refused to turn on. The next morning i checked the batteries with my multimeter and they are good, still reading 13 volt each, so i am trying to fault find at the moment.
As i understand the batteries are connected in series to give 24 volt to the controller, the controller then provides the motors with power according the input from the joystick.
This is the controller, the big red and big black are from the batteries, The pink,white and orange, yellow, goes back to the motors. So as i understand i should get 24 volt between red and black when the batteries are connected? there is no volts
So checking continuity between the red and the batteries connectors i get a beep, so all good, but between the black and the connectors i get nothing
So my logic tells me the wire is broken somewhere, but that is were i am lost, are these controllers straight fwd like that, or am i missing something, i can not get a wiring diagram no ware, so i hope someone with knowledge can please help me, this is my legs please help. This is the make of my wheelchair if that can help, to get a new one is not an option
