Help on bandwidth limiting.
moedawood
Hi. I have a Huawei B618 router and an Asus N14U ADSL router.
I want to limit my download speed of my lte and the asus router has this feature. How do I go about linking my Asus router to the Huawei to use the bandwidth limit feature? And if I cannot, please suggest what I can do.
please explain in as simple terms as possible.
Without going into the rate limiting of the router. If you have Windows you could look into Netlimiter. You can limit your internet connection with it at any speed you require.
Hi there,
While I'm not sure of the process using the other brand of device, DrayTek routers feature Bandwidth Limits as a standard feature, and its really easy to set up.
The following guide is in the DrayTek knowledge base - I hope it will also help you with the terminology and process for your configuration. Check it out at here.
If you want to get a feel for how its done, head over to this live web demo of a DrayTek Vigor2133 series broadband router's web interface: http://eu.draytek.com:12133/
Plug b618 lan port into n14u wan port
Should have internet on n14 lan ports
Disable b618 wifi and don't use its lan ports for other devices
