Help On Gta: Sa
Press the corresponding button when the circle goes over the button ?
That's if memory servers correctly.
Mebbe you just dont have rhythm ? ;)
Heh, it's exactly the same as the dancing.
Just hit the appropriate keys, it's not that hard.
The problem I had with that one was not knowing when to press the keys, and which keys to press.
When the arrow is pointing up and right, press the up and right keys at the same time, and press when the arrow is in the circle not just before or just after
Make sure you use the right keys. If memory serves me right you must use the numpad arrows on the right of your keyboard.
If you press the right key at the right moment the arrow will briefly blink white. If the arrow does not blink white you are using the wrong keys.
i am stuck on that stupid mission where u have to fly as low to the ground as posible so that the radar doesnt pick you up. Tried it twice and gave up.
It can be one of the most frustrating missions in the game. I found that circling around the forest before dropping the package helped because the trees can be really annoying and sometimes you have to use 1337 styles just to avoid them.
Plus you can take one rocket and still survive. You can even stay up in the air with some skill having been hit by two rockets.
just did that mission where you have to take madd doggs mansion back, took my like 2 freakin hours
