Help Please...Dust Problem
cAzmanian
Having huge problems at office where all the pc's are getting overtaken by dust. Any1 have any good ideas on how to stop it?
Dust on the inside or outside of the PC box?
If on the inside, does the case have a fan in the front and rear?
If on the front, try cutting a piece of cloth membrane that's used to seal the top of parapet walls, roofs, cracks etc, (can get from any hardware store in or near the paint section) - cut to size and place over the front fan intake - on the opposite side of the metal chassis to where the fan fits - I use rubber bands to hold in place, but you can use velcro, prestick, double-sided tape, etc.. It works wonders for me and keeps the case very clean inside. When the membrane does get a bit blocked up, I cut another piece and replace. I also blow out any dust particles that do manage to get through, every month or two...
