Help Please? Front fans aren't spinning?
InternetSwag
Hello guys, I have this Raidmax Alpha Prime case;
The LED fans in the front were working, then I took out the old PSU and put in a new one, now they won't light up/spin.
All other case fans are working.
These front fans are connected to the case, so I think they get their power from those little cables that connect to the motherboard. I'm not exactly sure, but now they not working.
Any advice?
Any advice?
You probably tugged on a wire and the power cable popped out that feeds those fans.
My old CMStorm Trooper had a molex connector feeding the fans and one of the contacts would pop out of the molex. Even if both parts were plugged in properly there would be no power until i shoved that contact back into the molex.
