Help please - MTN Nokia n70
Kellros
Just a few things:
Sms/calling works fine. I'm able to connect to MTN-WAP and MTN-MMS but there's no data transfer when i look under connections
- 0 kbps down / 0 kbps up.
I have requested all the MMS, E-Mail, WAP etc. settings from MTN but it still doesn't work. One thing that caught my eye was all of them use Packet Data,
but under Tools->Settings->Connections->Packet Data: There is no Access Point defined.
If anyone could help out with this it would really be appreciated.
Also I've read the connection method EDGE, GPRS, 3G is dependant on the area you're in. Currently the phone says 3G, but I don't know if that would have an affect on the fact I can't send MMS'.
Just a few things:
Had the same prob on another Nokia. Under the access point referred to in yr post, type in myMTN or Internet (depending on which AP's are on your phone)
Is this working now or are you still having a problem?
MTNDD
I also get a Packet Data Loss/error on my N70...Im with Mtn...I noticed this error occurs every +-2 days...Then i have to switch off and then ON again and itll work...Do any of you guys maby know of a setting for packet Data?...or should i use a Proxy? Also, IF i need to connect via a proxy, which one should i use and what should the settings be??...thanks guys...this f'n error i got since i received this phone ( 2 years now )
I tried your "myMTN" move, and so far it seems to work...If this will work BEYOND 3 days, i'll be amazed :)
I think its better to use the access point "internet" cause everyone is using the access point myMTN so I think traffic. Allthought they do use the same box.
