Hi all.
So this is the scenario. On my new (yet to fully move there) property there is the main household and a separate cottage area. In the main household most of the rooms are already wired for ethernet access. All this leads to a central location in the main house. I am not sure if the cottage is wired for ethernet.
Now my questions:
1. I would place the adsl modem in the central location. Correct?
2. Would it be better to buy a switch if I need more than 4 ethernet ports or do you get routers (with wifi) that can handle more?
3. I want to put another router in the cottage (use it as an access point) and connect it via ethernet cable. Or is it better to connect via wifi?
4. It's not possible to use more than one adsl modem on one line is it? Come to think of it this would be rather pointless. Only reason I am asking is that I am sure the cottage is wired for phone access but not sure if its wired for ethernet.
Your help in this regard is highly appreciated.
Now my questions:
