HELP !! ! ! ! Sony Z3 reset
The_Traveller
Guys, my son forgot what password pattern he used and I tried everything to bypass this.
I tried going into recovery mode where I would need to press the up/down vol button repeatedly but even that doesn't work.
I need this phone reset/recovered urgently ! !
Any tips/advice will be much appreciated.
LazyLion
King of de Jungle
So you tried this....
1. Turn off your Xperia Z3: press power key and select “power off” or press and hold power key for a few moments.
2. Power on your device and when the LED notification lights turn on press several times Volume Up or Volume down buttons.
3. At the end, your Xperia Z3 will be rebooted into recovery mode.
The_Traveller
Tried everything !
When I power on the phone no LED light comes on but I try pressing the vol buttons anyway, but goes straight to OS startup.
when I try to explore the phone, its blank.
The phone is totally locked until I put in the unlock pattern.
F
Fudzy
Guest
Maybe the phone has gone into some protection mode after too many failed logins? Try the recovery again after an hour or two.
The_Traveller
So exhausted with this shyte im done for the night. Tomorrow i'll give it a try again and see if anything changes. Thanks
LazyLion
King of de Jungle
[video=youtube;zkA4uCYTPFM]https://www.youtube.com/watch?v=zkA4uCYTPFM[/video]
LazyLion
King of de Jungle
[video=youtube;ZmmdQ3UdS38]https://www.youtube.com/watch?v=ZmmdQ3UdS38[/video]
The_Traveller
Lazylion - watched both those clips earlier and also nothing. It's unbelievable really ...
web
MY Z1 and Z5 have a reset button hidden in the sim card slot, does the Z3 not have this?
SCHUMI-4-EVA
Hmm, I've done a hard reset once but I remember that the volume up/down direction was reversed VS what I'd read on the internet. I assume you've tried both already?
The_Traveller
hehe, yeah ... tried everything ... my last resort .. going hypnotize the little one and make him remember the pattern
LazyLion
King of de Jungle
Can you take it into a cellphone shop? Surely somebody in one of the repair departments should know the reset procedure?
I can't believe that NONE of the above options work.
The_Traveller
After hours and hours of struggling, I made my son sit in a corner and never to leave until he gets it right.
And to my delight, he did figure it out ! !
Thanks to all for your efforts.
