Help with 9600GT
Tejen
Hey i have the xfx nvidia 9600GT.The problem is i don't know which 1 i hav i think its the standard edition not the xxx or alpha dog edition.So what im trying to find out is what are the frequencies for this card.The ordering code is PV-T96G-YMF4 the nvidia control panel shows the following:
core clock @ 650
memory @ 900
shader clock @ 1625
is this the correct specs for the above ordering code? And also is this card supposed to be dual dvi?
http://www.i-tech.com.au/products/30318_XFX_Geforce_9600GT_512MB_HDMI_PCIe.aspx
GeForceTM 9600 GT
Derived from next-generation GeForce™ and PureVideo® HD technologies, the 9600 GT 512MB (256 bit) graphics card pushes the gaming experience to new heights with 90% greater performance than any GeForce card in its class. Its powerfully immersive entertainment experience is the product of full Microsoft® DirectX® 10 support, NVIDIA Quantum Effects™ technology and ForceWare® Unified Driver Architecture. Pair it up with another 9600-based card for up to two times the performance of a single-card set-up. Add an nForce® motherboard to create the ultimate graphics platform.
KEY FEATURES
# Comparable to performance of an 8800 GTS
# Available in Extreme and XXX Editions
# HDCP ready for viewing High Definition movie content
# NVIDIA® Unified Architecture with GigaThread™ technology
# Full Microsoft® DirectX® 10 Shadow Model 4.0 support
# Lumenex™ engine
# 16x full-screen anti-aliasing
# Built for Microsoft® Windows Vista™ and Windows Media Center
# NVIDIA® Quantum Effects™ physics processing technology
# Two dual-link DVI outputs support two 2560x1600 resolution displays
# PCI Express® 2.0 support
# HDMI capable with the use of HDMI certified components
# HDMI Certified*
# 128-bit High Dynamic-Range Rendering
UNRIVALED GRAPHICS AND GAMING PERFORMANCE
> Combines the power of two graphics processors for ultra-fast, smooth gameplay at extreme HD resolutions with all in-game features turned on
> 30% to 50% faster than highest-end GeForce 8800-based graphics card
> High Dynamic Range lighting with 16x full-screen anti-aliasing adds cinematic realism
IMMERSIVE, EXTREME HD ENTERTAINMENT
> New PureVideo HD engine supports hardware acceleration of high definition movies and picture-in-picture content for the ultimate interactive Blu-ray and HD DVD movie experience
> Dynamic contrast enhancement and color stretch video processing optimized on a scene by scene basis for spectacular picture clarity
> HDMI connector enables sending both high definition video and audio signals to your HDTV over a single cable
Bus Type PCI-E 2.0
Performance Standard, XT, XXX, XXX Alpha Dog
GPU Clock MHz 650 - 740 MHz
Shader Clock (MHz) 1625 - 1790 MHz
Stream Processors 64
Texture Fill Rate (billion/sec) 20.8 - 23.68 Billion/Sec
Vertices/second (Billion) N/A
Pixels per clock (peak) 32
Memory Interface Bus (bit) 256
Memory Type DDR3
Memory Size (MB) 512 - 1000 MB
Memory Clock (MHz) 1800 - 2000 MHz
Turbo Cache Technology -
Output HDCP Capable 1
NVIDIA® CineFX® Engine N/A
NVIDIA® Intellisample Technology N/A
NVIDIA® Digital Vibrance Control® Technology N/A
Microsoft® DirectX® Support 10.0
Shader Model Support 4.0
Open GL Optimization and Support 2.1
Minimum Power Requirement (Watt) 400
Cooling Heatsink -
Cooling Fansink √
Output S-Video N/A
Max Resolution Digital Hoizontal 2560
Max Resolution Digital Vertical 1600
ROHS √
Dimensions L (Inches) 9 Inches
Dimensions W (Inches) 4.376 Inches
Dimensions H (Inches) 0.75 - 75 Inches
Dimensions L (Metric) 23
Dimensions H (Metric) 1.9
Profile Double, Standard
lol the 9600gt comes in "xxx" and "alpha dog" editions?
nVidia is nailing you guys!
Thanks for the quick reply defunct but all that information is written on the box.What i need is specific information on my exact card.The ordering code tells you what edition it is but i cannot seem to find information on this exact code.
core clock @ 650
memory @ 900
shader clock @ 1625
is this the correct specs for the above ordering code? And also does this card supposed to be dual dvi?
You have the standard one, I have the same readings in the control panel and I know I have the standard one. :)
You have the standard one, I have the same readings in the control panel and I know I have the stanard one. :)
ok cool thanks and what about the dual dvi output is it 2 or 1?
i'll check on mine, see if i can find anything that might assist...
...what is the chance of you uploading a pic or your card?
Weird, I cannot find your product code on the XFX website.
A google search within the "xfxforce.com" domain also yields nothing. The 9600GT manual also does not list that model.
Another plain google search lists results in countries like Australia, India, Singapore etc so I suspect your model is kinda unique to Australia, Oceania & Asia.
Have you tried registering your product on the XFX website yet?
Does registration work?
I have a PV-T96G-YDF4 which has the standard/stock frequencies which are identical to your listed frequencies.
These cards are easily overclocked,
http://www.bjorn3d.com/read.php?cID=1243&pageID=4567
http://www.techpowerup.com/reviews/NVIDIA/Shady_9600_GT
General info,
http://www.xfxforce.com/en-us/products/graphiccards/9series/9600GT.aspx
http://www.xfxforce.com/ecms.ashx/e...cab917/GraphicCardModels/9600GT_PS_US_108.pdf
http://www.skycomp.com.au/product.aspx?id=125448
Edit: I logged a general support request with XFX on your model# and will post what they reply.
I would think the change inordering code is just for the different outputs on the same card i.e. Dual Dvi an the other has one dvi and one Hdmi or something like that. The card itself is essentially the same.
Thanks alot for that ponder.Will be waiting to see what you get from them.
GPU-Z????
i tried that it has 2 readings one is gpu core and the other is default core so what should i bed looking for and also it shows nothin about which card i have just says 9600GT
