Help with Blender Animator
If I understand correctly, you want to create an animation to distort that board?
The first thing you need to do is mesh that board. There are plenty of ways to do this, and I'll assume for now (unless you state otherwise) that you are able to model this successfully. Next, depending on the version of Blender that you are using, you need to create bones. Read the documentation of your specific version (the exact names of the buttons, etc vary from version to version). Then you have to assign the bones to specific points in your mesh. Again, this varies from version to version, and you should consult the documentation. Once you have assigned this, you will be able to distort the mesh by moving the bones around.
Sorry if this wasn't very specific: I haven't used blender in a while. You should try looking for some documentation: I know there is a good online tutorial that walks you, step-by-step, through creating an animated gingerbread man.
Let me know if there's anything I can clarify
