Help with C++ Template/FileIO/Operator overloading please
CorneN
Consider the following:
Code:
	void ReadFile(std::vector<T>& vec) {
		std::string data;
		std::fstream file;
		file.open(m_sfileName, std::ios::in);
		if(!file.fail()) {
			while(std::getline(file, data)) {
				T obj;
				std::stringstream converter(data);
				converter >> obj;
				if(!converter.fail()) {
					vec.push_back(obj);
			file.close();
The function above is part of a Template FileIO class that stores custom objects with overloaded '<<' and '>>' operators. Works perfect, all fine...
BUT, if you pass it a vector<std::string> it only reads the first word of the string (surprise surprise) because converter only reads until the first space, unless the object has an overloaded '>>' operator.
So, my question is: Is it legal / advisable to create an overloaded '>>' operator for std::string?
Sorry if the question seems daft. C+ is hobby, not a job. So the exposure is not that great. :)
Ok, dont stress, I got it. Will have to create a small custom object to hold the string val and overload it's ops.
tks
Sorry dude, most of us are only really around during the day.
