Help with ceiling fan remote
Crusader
This side of Hell
My ceiling fan finally gave up the ghost completely. I purchased a Bright Star ceiling fan with remote which I still have to get installed, but I'm perplexed by the instruction for the remote controller and how to pair it. Anyone have an idea what on earth this could mean? My remote looks like the one on the right, without the "pair code" text on it.
Haven't seen one that bad in a while.
did you perhaps tried jou tube.
Yup. No luck. Can't find any videos for comparable fan and the remote only returns a manual with the same garbled text and a Reddit post of someone else asking for help with the posted image.
Thanks for all the help. Installation was done and the remote just worked without any pairing necessary. Will keep the video link saved if it is needed later on.
Can definitely give the instructions for this thing a 2/10. At least some of it were words you could understand. ;)
Have the exact remote, perhaps same/similar fans.
Do the blades fold when turned off ?
Anyway no pairing was needed. I’m
