On my work PC I have a wireless card and a normal network card. The network card connects to the works network and the wireless card connects to a wireless network that is used only for internet.
Is it possible to use both networks at the same time? Currently I have to disable the wireless card to use the works network and vice versa.
I can upload my 'route print' output if it helps
