Help with Kingston RAM
First thing to try would be updating to the latest BIOS to be honest and then take it from there.
The density might be too high for your motherboard, in which case there's no much that you can do.
Not many manufacturers specify the density.
Seems the problems was fixed. Did a bios upgrade, and boom, it worked :D Thanks for the help!!
