Hey guys, need some help please.
Been having some issues with my Linksys adsl / wifi router, so I decided to open it up.
What I need is more info on what's going on inside, so I've taken some pics.
btw, router is a Linksys WAG120N
This one is the main board.
My questions are: What's the big, square silver thing (red arrow)? It doesn't look like a chip, and the thing with the heatsink above it is probably the main processor. Could it be the wireless n antenna? (device is supposed to do wireless n).
I presume the 2 parts marked by the green arrows are the antenna and the antenna attach point? This appears to be the only antenna - is that enough for wireless G and Wireless N? (It can only do 1 at a time, so maybe that's why only 1 antenna?)
Here's a better pic, but without the arrows:
This is the back of the board, where you can see the square silver thing from the other pic has a smaller silver square piece on the back.
Now this is a plastic sheet under the board. What is it's purpose? Is it to conduct heat (the ventilation holes are below it). If so, it doesn't work very well as the device runs HOT.
Or maybe it's an anti-static thingy. In which case, it's blocking the cooling holes, can I remove it? Or at least make some holes in it?
Thanks for the help.
