Guys
Hi Recently bought a home theatre but only when i got home i noticed 1 HDMI port on it so basically i cant use it for my ps3
so here is my set up ps3 HDMI to TV then optical audio to home theatre
how good is the optical audio cable ? it wont give out HDMI sound but should be pretty close hey ?
i just want to make sure I understand your issue right
You just purchased a home theathre system and it only has 1 HDMI input is this correct?
I assume you have another device using the home theaters port? e.g DSTV HD decoder or something?
What I suggest you do if this is the case is get a HDMI switching box this will stitch several HDMI inputs via remote control to 1 HDMI output.
The output from the switching box would go into your home theatre system then the home theatre system would connect to your TV via HDMI.
This way you can have loads of devices working through 1 HDMI port on your amp
As far as the optical cable question go HDMI your Bluray moves and some games which you can play through the PS3 will not sound the same via optical cable. You will not get True-HD and DTS master audio the new HD sound formats though the optical cable.
Don't worry about having an amp that can decode these formats because your PS3 can decode them onboard.
