help with Optical Audio
OMG!!!
Guys
Hi Recently bought a home theatre but only when i got home i noticed 1 HDMI port on it so basically i cant use it for my ps3
so here is my set up ps3 HDMI to TV then optical audio to home theatre
how good is the optical audio cable ? it wont give out HDMI sound but should be pretty close hey ?
I got a pretty good optical cable running from my TV to the amp, gold plated and armoured as well, and the sounds from the PS3 is 100X better than from my DVD, even though my DVD is connected direct to the amp where as my Ps3 has HDMI to TV.
ohhh maybe i got a ****ty one then i only payed 60 bucks for it ??
dam should have never bought that home theatre made a big mistake there
ok so i got it right then
DSTV to HT = RCA cable yellow and white HDMI to TV from PS3 then optical cable from PS3 to HT
ok so the point is ioptical cable is good ?? at least for gaming ?
Optical sound from PS3 to a 5.1 system is amazing, you wont be let down.
I think if you wanted 7.1 surround sound, then you would have to use the HDMI, could be mistaken though.
Nope optical cable is better for sound than HDMI
id prob go with HDMI cable ? but you would need the AMP that could transcode 7.1 sound
Why would optical be much better?
They are both digital signals so they are both excellent and no having gold plating won't help either of them except con you out of money :P The only problem is that the PS3 won't output 7.1 channels through optical. I have a 7.1 amp and speakers that uses only optical and the sound is still exceptional even though the amp forces 7.1 from the PS3
I'll avoid those all in one systems if at all possible. Ask yourself what you actually need and realise that you are paying extra for all in one products from sony and samsung. You might be surprised to find that you can buy a higher end system for not much more than those all in one box systems.
Going back to your original question, you really don't need hdmi if you are buying a 5.1 box system. Optical will be fine in that case
Yeah true pity i bought it already
suppose i could do with another 1 in the house ? for the extra bedroom maybe
i know thoise all in one systems are not the best thing to get
Surely the original sound would have to be recorded so as to take advantage of 7.1? I mean, a mono original is just going to give you the same noise out of each of the speakers.
