Help With Sharing Bandwidth Equally Over LAN?
k00l_3
Was wondering if it was possible to share bandwidth equally over a lan?
I have a Billion 7402 adsl router that 4 pcs are connected to, as soon as one of the pcs download something the rest of the pcs have slow access to the internet, is there a way to limit the amount of bandwidth that each pc uses so that each pc has equal internet access speeds?
Any advice would would be greatly appreciated.
That would b speed based not bandwidth.
Both can be limited with a software called Netlimiter (installed on each pc).
Various other softwares available
Sorry not an expert......
will this "Netlimiter" limit all aspects (p2p,browsing,voip) ?
Freedownloadmanager won't help for other applications/ports/lanning....
I'm also looking for a solution, but I would have loved it if the router could have managed this. But Netlimiter would prob be the best option for now, thx!
CCProxy will do the job.:)
http://www.youngzsoft.net/ccproxy/
CCProxy
Proxy server CCProxy is easy-to-use and powerful. This enables you set up your own proxy server and realize Internet connection sharing within 10 minutes. CCProxy includes innovative features like Internet access control, web filter, bandwidth control, web cache, parent, remote dial-up, auto dialup and time schedule puts you in a complete control of the Internet access. It also provides some advanced and interesting functions. Proxy software CCProxy can well accommodate your Internet sharing whether for business or home network.
