Help with Solr and Apache - running on Debian
web_dude
Joburg
Hi,
Anybody can help with Solr?
I have a webservice that runs on any web backend (Apache in this case) but the search function is set to be with Solr. I have both running on a debian machine. Apache is running, the webservice is running and Solr is also running. The problem? I cannot point Solr to make the search function works!
I tried to make a another core and I all that, but i'm not winning. Wondering if someone here can assist.
Sorry, I haven't worked with Solr before.
Did you start at the bottom? Check logs, ports etc?
Make sure that your config is correct.
I am just pointing the usual stuff out.
