Help
marine1
A black hole in the universe - JHB
Here is the problem.
I have the following:
Windows 7 x 64
Gigabyte x58 UD3
6 gigs Ram OCZ triple channel DDR3
Ati 5870
Intel I7 930
When I play BF bad company 2, everything is fine until i get into the map. After a few seconds, it freezes my machine and I need to manually reset the machine.
Anyway to find out whats causing this?
I think I found the problem, its because my version of Windows is not 100% kosher, the WAT removal tool seems to be the issue :(
Yeah yeah I know I should be running a legit version. :(
Why remove WAT if you can work around it leaving the product in tact and appearing genuine?
lol remove wat is the only way
ive wasted a few mellenia looking for a bypass crack
remove wat is the only thing that i could find
(i got the origonal so it izint piracy :p)
Erm, google Windows Loader v1.8.2 by Daz
About
This is the loader application thats used by millions of people worldwide, well known for passing Microsoft's WAT (Windows Activation Technologies) and is arguably the safest Windows activation exploit ever created. The application itself injects a SLIC (Software Licensing Description Table) into your system before Windows boots, this is what fools Windows into thinking it's genuine.
Yeah I thought evryone used a loader.
:eek:
This is shocking, what do you just sit with windows tuning you that you are running a pirate version? haha. Marine if you are going to pirate do it proper mate :D.
What nick are you using ingame? What servers you play?
