Not getting any luck on the other subforum so i'm trying here
need a little info please
after much delay i finally forwarded my port yesterday (i was afraid i'd mess something up previously)
anyways the network test on utorrent showed it worked perfectly and that my port was infact forwarded!
only thing that bothers me is that the internet light on my router still shows as red even though i can connect to the net .. why ?
another thing i picked up this morning was that the network test was now showing limited traffic through that port were as yesterday it was open.... what changed over night ?
one last question, i'm with mweb should i leave the DSL in my username or remove it ? reason i ask i cos i see the rep asked a few peeps to remove the dsl for a better connection, i'm not sure if that situation has now changed and weather (sp) or not i should remove the DSL....
.... another question about this setting in my router ... i have two options RFC1483 bridged and RFC1483 bridged with LLC or something ....which should i choose ?
thanks
You want to change the encapsulation to RFC1483 Bridged
thanks
