Hemp oil curing cancer?
_Hecate_
Has anybody taken hemp oil to cure cancer? I've started reading up on it as a friend of mine who is only 30 got diagnosed with cancer :(
So far I have found testimonials that it works..but not really why it works. Some list a correlation between increases in the level of melatonin that helps heal your body.
Don't know about the hemp oil bit - worth a shot I suppose.
I don't think their is any magic bullet though.
Try and get the video - "healing cancer from the inside out - mike anderson
Certainly is food for thought ;)
It depends on the type of cancer.
THC (not present in Hemp oil) has shown to halt brain tumor cell growth and sometimes shows recession.
I get the feeling that Cannabis has some sort of magic within it relating to cancer cures just because of the stigma associated with it.
Yes it does cure cancer... I have just given a whole bunch to a friend of a friend, he's in pretty bad shape.. I am positive all will be well.. :)
So does alkalizing and detoxing the body.. Most cancer is caused by blockages and toxins in the lymph system.. Detox your lymph system.
http://www.facebook.com/DigitalAwareness
All I want to say is take internet conspiracy videos with a grain of salt (It can be amazing what people will accept as "evidence"), sorry about your friend.
Whatever other alternative stuff your friends decides to swallow just make sure to recommend that he/she sees an oncologist.
I won't bet my life on something that hasn't been through trials if I have a tested known effective alternative.
What utter schit.
You cannot possibly know this. Try to think about how such information could possibly be gathered in any reliable fashion.
What utter schit.
This ^^^
As far as I know there is some evidence that cannabis oil (not specifically hemp oil) can reduce the size of cancer tumors. The evidence is quite limited and I think the jump from this to 'it cures cancer' is too large. So no, not enough research has been done to be able to make this claim. However, it doesn't do any harm to try.
theintelhub.com/2012/05/21/marijuana-oil-helps-3-year-old-son-beat-cancer-dad-says/
Absolute BS.
detox will not cure cancer.
You need to watch Running from the Cure- The Rick Simpson Story as mentioned above but most importantly you need to understand the difference between hemp oil which is cold pressed (like olive oil from low/no THC varieties of agricultural hemp) and the hemp oil which seems to help/cure cancer. This is the essential oils of normal/high THC cannabis and is made from the leaves and flowers of medical grade cannabis. Completely different oils.
Thanks I will check it out, already have a few "suppliers" but I'm worried about the quality. Would rather attempt in making it myself.
You are a dangerous moron to have around. Your friend should really rethink the company he maintains.
OP, to the best of my knowledge, Rick Simpson is the lone purveyor of the cannabis miracle. Even though cannabis has been extensively tested on cancer patients in some of its purest forms, Rick Simpson still claims without a shred of actual evidence that it can cure anything from cancer to AIDS to bad breath to lupus. Anyone who makes such claims (and then profits from the subsequent clamouring to devour his special brownies) should be trusted about as much as a politician during elections.
There is certainly evidence that cannabis can have a positive impact on cancerous tumours (albeit a small one), but I hardly doubt there exists any evidence that hemp oil can do anything but stain fishing hats...
Absolute BS.
You need to do more research on the topic, people have cured cancer by drinking green juice (Alkalizing Detox!) in weeks! Cancer can not survive in and alkaline and oxygenated body. Alkaline tissue holds up to 20 times more oxygen then acidic tissues. Hemp oil cures skin cancer in a week when directly applied. I don't know the exact medical terms but the CBN's surrounds the cancerous cells(mutation caused by build up of waste from lymph not cleaning the cell properly) and blocks them from interacting with the body. They basically dies off then. The human body is designed to regenerate, the only thing stopping it is the toxins that we put in daily. If you detox the heavy metals and years of other crap that's in your body including parasites and emotional blockages.. the body will regenerate to its perfect form.
Research a few of these things in Google and YouTube..
Orums - everybody needs to find out about this stuff!
Dave the raw food trucker
Life regenerator
Run from the cure
Curing cancer with BICarb (another form of alkalizing)
Forks over Kinves
The future of food
HyperionTV
The internet is full of good videos and new information..
p.s. we all have cannabinoid receptors inside of us, which help regulate our entire body. That's why your body is brought back into a balance when you smoke a lot.. But it also show's us that we have been living along side and using this magical plant for many generations after generations. We have evolved into having a symbiotic relationship with the plant in many ways other than consuming it. If researched properly you will see that it is probably one of the most important plants on this planet for reasons other than just smoking and medicine.
Negative state of mind and stress can also cause acidity in the body.. :)
When a person is dieing they tend to be a bit less ignorant, and they are willing try open there mind to other possibility's..
Your ignorance is dangerous and will stop people from getting the help they need. It's ultimately each to his own when it comes to the route he takes to heal himself, but at least give him the options.
Rick Simpson doesnt profit, he gives it out for free. In fact he has suffered greatly for his beliefs. And his beliefs are simply that the oil he extracts seems to have cured his friends from cancer and himself from the aftermath of a serious work injury. He simply puts it out there- like it of lump it. If you havent seen his video yet then perhaps it isnt fair to criticise just yet? Also he isnt a lone purveyor.
