tkbaby
Hi everyone
This is my first post on the forums, judging by what I know of the users of my broadband, I am going to get some really good and accurate advice.
Let me explain my situation, mention what I am thinking, ask my questions, and see if anyone can provide some solutions for me.
My wife and two kids (kids under 3) are moving into a new house come November. It is a reasonably large home of about 300 square meters. The DSL jack is in the study, which is off the main bedroom at the back corner of the house. I would like my entire house to have good signal strength for wifi. So that I can access wifi throughout. As a result from the bedroom it needs to reach to the rest of the house through quite a few walls to ensure pretty much full signal or close to it throughout.
I currently have a Netgear wireless modem/router that is 802.11n. Not sure if its 10/100 or a Gigabit. Devices to connect at this stage would be phones, laptops, tv, desktop pc and wireless speakers (not bluetooth). I would like a solution that will allow me to keep up with newer devices going forward. Currently only two phones and one laptop is 802.11 ac compliant.
Regarding use of wireless, connect to DSL (fastest in my area sadly only a 4 mbps line and I don't see that changing soon), stream music to my speakers from laptop or desktop or through online streaming service, use an external to back up onto from phones or computers, and also stream series or movies or music off of (won't really be downloading Full HD movies or series, but might) to TV or computers. Stream internet from TV, print wirelessly and so on. Going forward I may want to connect CCTV cameras and so forth.
Now that you have info regarding my house and devices and uses, let me tell you what I am thinking. Advice can be on the options I have identified or options I have not thought of either will be welcome. Ideally I am thinking of going 802.11ac route, to ensure fastest transfer and thinking of the future. Also it seems you get better range or throughput that way. It also mostly comes at least dual band which allows me to get certain devices to connect on the 5GHz band freeing up "space" on the 2.4GHz band.
I am considering the following options:
1. Buying an AC router. Connecting my Netgear as a modem. Running a cable to the new router that has been placed more central in the house thereby giving me better coverage. The wifi on my Netgear would be off and I would use it purely as a modem but will hardwire my desktop to it in the office. Due to it only being used as a modem it does not matter if it is only a 10/100 modem due to our limited DSL line speed. I am hoping I will have strong coverage throughout the house this way, and can connect all devices to the router. I will connect an external to the USB 3.0 port of the router and also the printer possibly. The router I am looking at would be a triband, or is that overkill? I was looking for ones with best range etc. So I was thinking of the ASUS RT AC3200 or the D Link DIR 890L. With my laptop being a macbook pro and my wife and I will be going the iPhone route with next upgrades, I was also thinking of the Time Capsule. It is not available in SA but I have friends coming from USA. It is a ac dual band router with a 2TB external. This will make backing up of data esp photos and videos of kids easy, I suspect. With these router options, I was hoping I could get signal throughout at good speed. But perhaps overkill on the router for what I have and even where I may go? Is an AC router the way to go, but maybe not triband? Maybe only dual band needed?
2. The other option is to stay within the 802.11n protocol and get some extenders throughout the house. I know many people recommend the unifi range from Ubiquiti. I have no experience of them so if that is a suggestion, what ones should I consider. My router, which is currently in storage is about 5 years old, so think the wireless speeds not great. So for backup and streaming not sure a wireless AP keeping my current router solves my problem.
3. Another option I have considered as a solution is to get a decent 802.11n router. To set things up and use it the same as option 1, but with only an N router perhaps even a dual band one.
So really where I am needing advice is considering my needs do I need the speed of ac or is n sufficient? I don’t want to wait an age to transfer files to my external which is connected to a router etc. But maybe paying a couple extra grand is not worth the convenience. I plan to set up my house with wireless speakers, not just one or two, so don’t want delay or dropoff due to slow network.
As far as budget, as always, as cheap as possible. But I know you need a figure, so a max of about R3 500. Those AC routers I mentioned are more than that in SA but have family returning from Australia and can pick them up at about R3 500.
I hope I have not bored you or over shared with useless info. At the same time I hope I have given you enough info to try and provide me with a solution that is affordable and will suit my needs. As I said earlier I have always been very impressed with the knowledge and helpfulness of mybroadband users and I am sure this will prove no different.
