Home smoking
APoc184
Tshwanetoria
Has anybody here ever smoked their own bacon, chicken, etc?
Did you buy a smoker from like Weber or did you make a DIY smoker?
What chips should you use? How long?.... So many questions.
Really interested in trying this out.
Plenty. Cape something or another wood chips. Pan, rice, herbs, whatever you like. Meat and veg on a raised Tray high above the smoke. Covered in an old bucket. It's about as DIY as it gets... :D
I love those smoke contraptions on the telly. but it would be very expensive here I reckon.
I haven't seen anything but the simplest ones ive seen on the telly is a round tube that ends in a thinner tube on top. there is a grid about halfway with the wood/heat coming from the bottom. haven't looked on the web yet though.
Just take care:
3.1.1. Hot Smoking
Hot smoking is done in the smokehouse or more modern electric kilns, usually over a short period of time, just until the meat is cooked. The meat is cooked and smoked at the same time over a burning fire or electric elements of a kiln.
3.1.2. Cold Smoking
“Cold Smoking” is done over a much longer period of time, e.g. 12-24 hours, over a smoldering fire (below 85°F). Since foods are held in the temperature danger zone, rapid microbial growth (40-140°F) could occur. Therefore, only those meat products that have been fermented, salted, or cured, should be cold-smoked. Most cold-smoked products should be cooked to an internal temperature of 160°F before they are eaten
http://nchfp.uga.edu/publications/nchfp/lit_rev/cure_smoke_postproc.html
I've smoked a few joints..... of meat in my time.
I use my weber kettle braai - its called the minion method. You want a slow burning flame that will produce lots of smoke. I use a mixture of charcoal and wood chips, and light one end. It burns for 12 hours or so. Put a foil try with water in it underneath the meat.
Remind me to upload a photo of how to do it. To me, it produces the tastiest meat that you can have from a weber.
One more thing perhaps worth mentioning is the different kinds of meat that you would use for smoking. In any animal, the parts of the animal that does the most work (ie legs and shoulders) are the most flavourful but also the toughest. The parts that do little work, like the rump and spine, are less flavourful but more tender. Tough cuts of meat are tough because they contain collagen. If you just grill a piece of brisket like you would a steak, the collagen does not have time to dissolve, and you end up with something tougher than an old boot. Cook that brisket low and slow, and the collagen breaks down into gelatin, and the meat becomes moist, tender and flavourful. Also, cuts from the front of the animal, like pork shoulder, pork belly or beef brisket, are full of fat. If you cook them low and slow, a lot of the fat renders out, but enough is left over that the meat is still very tasty and moist. If you did this with rump, it would be very dry.
I dont know whether low and slow works for chicken - I suspect you would want a higher temperature to ensure it is cooked without it drying out. If you want to start doing this style of cooking, get a meat thermometer - it will make your life much easier, and reduce or eliminate the possibility of taking off meat before it is ready, and exposing yourself to dangerous pathogens. Anything you smoke needs to be cooked to at least 74 degrees C. For pork shoulder and beef brisket to be tender, they both need to be cooked to 85 degrees C or so.
Thanks for the scientific input their guys - will be sure to get a decent thermometer.
I know some guys that can do steel work - but having to decide on a design that is hopefully not going to break the bank.
Though for something like this, I suppose you'd want to do it right.
Brisket and pork shoulder and belly is what I'm looking to play around with.
I've done both brisket and pork belly, low and slow in the oven.
But really wanna step it up with a brine and smoke recipe on the pork side of things.
I think Google a few stainless steel smoker designs. I'm sure the Americans will have plenty.
To my mind, you either want want a tall vertical smoker like the weber smokey mountain, with the fire below, or an offset smoker design. An offset smoker refers to having the fire in a separate box to the meat, and having them connected by a pipe. That way, the smoke reaches the meat but not too much of the heat. Come to think of it, an offset smoker might actually get too cold for hot smoking.
